Rear adjustable control arms
Punisher
West Chester pa
Just installed a Iron Rock Offroad 4 inch lift with adjustable upper control arms. Rear is out of alignment, considering adding lower control adjustable arms to try to get everything aligned. Have transmission drop and can't pull off SYE yet. Thoughts?
If no SYE yet then set your adjustable arms to stock length. The pinion angle needs to be parallel to the output shaft angle. Your pinion looks quite high
Reactions: Flivver250
