Rear axle seal leak
Flivver250
Dubai/Florida
I replaced the rear seal a few months ago, had a 4x4 shop press on the new bearing because I could not wait for the new complete kit to come. Well, as bad luck would have it, the replacement seal started leaking. I had the shop install the new axle for me, and it leaks even worse. Going to tear it down tomorrow and see what gives. Zero dents, zero rust and corrosion inside and out. How stubborn are these D44s?
It is possible they put the retainer plate on backwards which will allow the seal to back out. A pic would help to see if it is correct. If done correctly, the set 10 usually seals up just fine.
