Rubicon axle leak
Brian Alcorn
Ok so my 04 Rubicon rear axle is leaking at the drivers side seal and the yoke mechanic wants 125 just to do the axle seal ... I can do the yoke but dont have a press for the axle shaft bearing and ring... I've been told that the seal will wear a groove in the shaft and the new seal will leak ...is this true and should i replace the shaft as it has 315000 miles... rearend was rebuilt 4 months ago and been leaking ever since... had words with the shop so I cant take it back there
Jerry Bransford
TJ Guru
Escondido California
Try sliding the axle shaft out and smearing a thin layer of Mopar RTV, Permatex Gear Oil RTV, or Permatex Ultra Black RTV (in that order) around the outer edge of the seal. Clean the opening to the axle tube where the seal seats before sliding things back together.
Reactions: Steel City 06
Steel City 06
Pittsburgh, PA
If you have been considering upgrading to chromoly shafts, the shafts already come with pressed on bearings and seals. Not cheap though, but one of the easiest upgrades to do
Brian Alcorn
Brian Alcorn
Where would I get the shaft as extreme terain says theirs is just the shaft without bearings or seal or flange ...has to be purchased as a kit seperately
Steel City 06
Pittsburgh, PA
These would have the bearings and seals, and are considered to be a very high quality shaft by many site users:
I bought and installed these and it was relatively straightforward. Hardest part was reassembling the parking brakes
Here is a moderately cheaper brand that also has fans on this site:
(I have no experience with these myself)
Jerry Bransford
TJ Guru
Revolution Gear axle shaft kits come pre-assembled, everything pressed into place, and ready to install.
But for now, yes the RTV should be uncured for the above suggestion.
Brian Alcorn
Brian Alcorn
Guessing that's per side
Brian Alcorn
Brian Alcorn
Ok so the carbon off road fits rubicon ... didn't see it listed and not sure of the difference other than the factory locker
Brian Alcorn
Brian Alcorn
Thanks Mr Bransford... as I am discovering reading around this forum you are the go to know all for TJs
