Rear brake line replacements - Help with part #s please
Bushfamily5
Las vegas
New to me TJ project just gets better and better!! I now have a brake line leak in the rear left brake line. Believe its the 1 piece line. I want to replace both sides. I will also replace the fronts with the Dorman extended replacements and the center rear one as well. Got those part #s from another post during my search.
Can someone help with a replacement part # for those 1 piece rears?
Thank you
Discs or drums? ABS or non-ABS?
For drums, unless you're bending the hard lines yourself, you'll likely get a set that includes both right and left rear lines. Follow manufacturer instructions on properly seating them in the wheel cylinders to make sure they seal.
I grabbed a set from https://www.inlinetube.com/ for my rear drums and they've worked great since.
From my 2005 TJ Parts List doc:
  • Left rear disc brake hose + tube (non ABS): 52128431AC
  • Right rear disc brake hose + tube (non ABS): 52128430AC
