I have the same switch! Only mine is a EU spec for rear fog lamps, but it is the same switch. When I tested it out on a Euro TJ it worked just fine and it kept the fog lamp on.
Yes, the one I have is a momentary switch. So you're telling me that the front fog lamp switch (from the ebay link), which looks the same on the outside, is not a momentary switch? i.e. works like the rear wiper switch and latches itself in the ON position after you push it?
It's a US spec vs the Euro spec and needing the "smart" (latching) relay.
I have a switch that you could have, but it says "zombie lights" on it. Would that pass inspection? Does your inspector have a sense of humor (or is it humour)? I could drop it in the post forthwith.
Thanks mate but I checked with the MOT station and the Fog lamp indicator needs to have the symbol on it. I guess I'll just buy the green relay and wire it like the factory....
Only 20 GBP which is roughly 25USD I think. They were used on Cherokees as well so availability shouldn't be a big issue. I found another one for sale in France for 6 EUR, which I'm gonna get to keep as a spare.
I’ve just check the bulb and it is fine. I’ve also checked for power and the bulb contacts I have 0v. The connector behind the rear bumper also has no power to it. Do you happen to know what the pins are for feed and ground?
