Rear Pinion Angle 2 Degrees
dieselvrr
Fairfax VA
Quick question, just installed my 3.5 metalcloak lift and tom woods 1310 shaft. The driveline angle is at 18 degrees and pinion at 16 degrees. Drove about 40 miles today and notice a little rhythmic vibration at 45mph. It goes away at 50 mph. Will 1 degrees from "optimal" (pinion -1 degree from shaft) cause rear vibrations?
Set it the same angle as the drive shaft, so rotate the pinion up, also check your front pinion angle too.
You would be right on a lefspring set up, due to spring wrap, but a 4 link coil set up is designed to maintain a consistent angle, or change in angle, through its range of motion(arc), depending on arm length and mounting points.
So 2* off, is still 2*, yes moving the pinion 1* fixes it, but that’s because the pinion is down 1* and the driveshaft is up 1*, so moving 1* doubles the amount moved and changed the angle by 2*.
Reactions: dieselvrr
