Rear spring pads / isolators / cushions
dodj
Canada
Replacing the rear springs with new BDS units. When removing the old ones, I see there was a rubber pad or whatever it's called on the upper spring perch. Nothing on the bottom. Is there supposed to be something on the bottom? :unsure:
There are isolators top and bottom in stock form. The upper are rubber-like. The lowers are plastic and have tabs that engage the 3 holes in the axle spring perch. Some say the lowers aren’t necessary. In support of that idea, the front springs don’t have them. I replaced my rear lower isolators recently with Delphi parts from Rock Auto.
Reactions: SSTJ
Did they make any difference? Less noise?
Uppers seem to be consistently there throughout the TJ run. The lowers disappeared at least as late as 2003. I have never actually seen a set of rear lowers on the dozen or so TJs I have spent time on.
Fwiw, mine has been with and without rear isolaters multiple times at various stages. I could never tell a difference in noise. Same with the front. No more rubber up there and nothing changed.
I doubt they do (lowers, I mean). But I haven’t done the experiment with and without. I replaced my uppers and lowers when I had my axle out because my ‘97 had them and the original lowers fell apart on removal and the uppers came with the lowers. Intuitively, I suspect the uppers may make at least a little difference in NVH but maybe not enough to be noticeable in a TJ.
Upper vs lower doesn't matter. The NVH is passing through a big spring. I suspect the real purpose of the isolaters is to reduce squeaks from the metal on metal contact. Even then, I rarely hear squeaks from the springs despite having lots of metal on metal contact at the springs.
So I guess the consensus is they don't really matter....so I'll install the springs tomorrow without.
Thanks All
Reactions: jjvw
NVH?
Nasty vehicle harmonics?.........:rolleyes:
Noise vibration harshness. It's a catch all acronym to describe things relating to bushing isolation, shock tuning, tire pressure, things that transfer from the road into the cabin.
Reactions: dodj
