So my rust bucket started to make a new noise the other day.. Looks like the rear upper passenger side control arm has broke. I order all 4 arms for the rear with new hardware and will begin the replacements probably tomorrow night. I have read that I should replace one at a time, return to ground and then torque.
But I still have a few questions about the job.
1. Should I be worried about how much I have driven with a broken CA?
2. I do not have a lift, do I need to be concerned with any kinds of measurements? The arms can only be one length, I assume.
3. When replacing one at a time, drop the vehicle after each arm and torque down, or replace all leave the bolts free and then torque all at once when it is on the ground again?
4. Since I have all new hardware can I just cut out the old arms, clean the brackets and then install all the new?
5. I am also replacing the rear shocks while I am back there. I have already replaced the gas tank skid so dropping the tank will be easy.. should I drop the tank again to make access that much easier.. or is that really not required?
Just ordered the rear sway links and bar too, figure.. while I'm there
Thanks in advance for the knowledge.
