Rebuilding Hubs
Reactions: Irun
@JMT I found the archived copy of Stu Olson's website, here's the part of it that shows how to get the unit bearing hub off. https://web.archive.org/web/20180303174901/http://www.stu-offroad.com/axle/Dana 30/axle-1.htm
Roam around his site, it's awesome! @Chris maybe we should add a link to his archived website https://web.archive.org/web/20180303164204/http:/www.stu-offroad.com/ to our resource section.
Thanks. Nice to have Stu’s archived site. Lots of good stuff on there!
Reactions: Jerry Bransford
With all the rusted bolts on this one I hope we get the bolts out. Now I’m getting worried. Thanks for the heads up. I’ll add some heat before.
Just be careful with the heat. One bolt is near the upper ball joint and another near the tie rod. If you're breaking it down that far, it's a good time to replace the ball joints (If they haven't been replaced).
Reactions: BlueC and JMT
This was a great bit of insight in removing a rusted hub. I found on Stu’s site. Atributed to @mrblaine.
Before applying heat try soaking the bolts several times over a couple days with Liquid Wrench, Kroil, or Break-Free. Don't waste your time or $$$ trying PB-Blaster or WD-40 on that job.
Having done quite a few unit bearing replacements, I suggest having a BFH on hand and good penetrating oil (ATF and acetone). When you start finding resistance on one side, let it soak while you work on the other.
Whelp, I was on the fence about the ball joints but I guess I should consider those too. All this just for a couple of u-joints! 🤣
Reactions: Irun
Mark off a day to get all that done
Reactions: Irun and PRNDL
Crap, this is turning into a big project. Not even my rig. It's my 16 year old sons. I might have bought something I shouldn't have bought. This thing needs so much stuff. 🙄
Yeah but your 16 year old son is counting on you lol. Been there done that, mine is now 30! Yowsa!!
Reactions: JMT
With the age of these now, most do. I know that when I buy one, I'm going to spend about $3000 - $3500 in parts to replace worn out or old stuff! ;)
Reactions: JMT and BlueC
If you decided to go with Timken hubs, double check them for wobble, there may be a defective batch floating around.
First set i received was so bad i could tell it was off before mounting wheels. Replacement set was terrorizing me for a month with vibrations before i figured out that it had slightly eccentric spin.
Reactions: Irun
I hope not. I've had a set sitting on the shelf for a few months now. I'd be pissed if I had to toss them.
Fucking amateurs and their full lack of creativity. If they are bad, buy a new set, toss the bad ones in the boxes the new ones came in, return for a refund. Defeats all of expired warranty return windows that way. And it isn't even cheating, just exploiting a loophole they created that they shouldn't have.
Not that your'e looking for even more parts to replace, but when i did mine i replaced both brake dust shields. The originals were in sad shape.
  • Sad
Reactions: Fouledplugs and JMT
