Hello Everyone. My son and I have been working on our ‘97, 4.0L Manual with 200k for a few years and this site has been a life saver for two Jeep Noobs. So first thanks to the forum and help on so many issues
We’ve had some clutch problems and decided to replace the clutch. The transmission and TC case are out and we need advice on several items:
1. The underside is a mess and we wanted to move the TJ so we could pressure wash the underside. Is there a way to do this with the Trans removed and the engine temp supported? Is there a way to temp brace the engine? And secondly, with the pressure plate exposed is getting things wet a concern?
2. Now that we see the cutch and throw out bearing that look fine the problems we’ve been having are likely the very leaky transfer case. If we have the TC rebuilt (by a pro) should we also have things done to the AX15 trans? (We pulled them as a unit).
3. With the trans and TC out we’re thinking about replacing the shifter linkage and maybe installing an SYE for a future lift…is there any else we should think about doing?
4. When pulling the trans we stripped the top Torx at the bell housing and had to cut the head off. I cut into the outside of the bell housing pretty good, but it’s still “boltable”. Any concerns with this?
Thanks in advance for the help.
