U underdog New Member Original poster Joined Sep 21, 2019 Messages 1 Location SC Oct 12, 2019 #1 I need to replace my rear pinion seal and was wondering what type of differential fluid would be best to refill when I’m done. thanks
JMT The Silver Fox 🦊 Supporting Member Ride of the Month Winner Joined Feb 27, 2017 Messages 27,640 Location 🌎 Oct 12, 2019 #2 If you pull a trailer, a heavier 85w-140. Otherwise, 85w-90. Use conventional gear oil
Leinhit TJ Enthusiast Joined Sep 26, 2017 Messages 449 Location MI Oct 12, 2019 #3 JMT said: If you pull a trailer, a heavier 85w-140. Otherwise, 85w-90. Use conventional gear oil Click to expand... What about the front diff?
Mr. Bills Raconteur Emeritus Supporting Member Joined Nov 24, 2017 Messages 4,394 Location Area Code 605 USA & Código de Área 661 Mexico Oct 12, 2019 #4 Leinhit said: What about the front diff? Click to expand... Conventional (non-synthetic) 85w-90 in the front. Reactions: Leinhit
Mumblewood TJ Enthusiast Joined Oct 9, 2019 Messages 936 Location Renton Wa Oct 12, 2019 #5 I use convention 85-90 both ends also, I check often and replace 1-2 times yearly.
G GASnBRASS TJ Enthusiast Joined Apr 6, 2017 Messages 688 Location Minnesota Oct 12, 2019 #6 Conventional gear oil. Synthetic is actually a poor heat carrier so while the diff cover might feel cooler the gears themselves will run hotter. Reactions: Jerry Bransford
chino1969 TJ Addict Supporting Member Joined Apr 14, 2019 Messages 1,217 Location Oxford, PA Oct 13, 2019 #7 I am using conventional 85W-90 front & rear. Recently re-geared with G2 gears along with a Tru Trac limited slip in the rear. Will never run synthetic in these diffs.. Reactions: Jerry Bransford
