I would not run a synthetic if you are planning on doing any towing or offroading. Currie did tests a while back after a few warranty claims on their axles and it wasn't until they tested synthetic vs conventional that they realized the conventional is better at heat transfer and the synthetic was causing their issues.
I've been changing out my fluids considerably more often than is needed due to various work. With my numerous water crossings I aim for once a year (in the fall so water won't freeze in them over the winter) which tends to be about every 8k miles. It all depends on what you're doing with them imho some people will be fine at 20k+ I'm sure.
Amsoil tends to be pretty good stuff. Anything that they have formulated to spec I run. You might want to actually look into it before bad mouthing it.
FYI for anyone who reads the study - It was commissioned by and paid for by Amsoil.
If anyone thinks that it is coincidence that Amsoil scored highest of the gear oils tested should contact me immediately. I have some swamp land and a bridge that you might want to buy.
