Replacement for brake partitioning valve
Sam’s in Tulsa installed the front axle, steering and suspension systems. Is there a shop in Arkansas that you know of who could diagnose and fix the brakes plus the root cause?
Reactions: Rickyd
I'm not sure where you are in the process of diagnosing this but i can call bs on abs vs non abs prop valves making any difference. I used an abs valve with a non abs system by swapping a fitting. It sounds like you are having master,booster or pushrod adjustment issues. In addition to your brake hose or caliper problem
Reactions: OzarkJeeper
@mrblaine final diagnosis from the mechanic today was improper steering stop installation causing driver side to go past the appropriate point and make contact with the caliper. They believe the slight contact left a mark on the caliper, caused interference with the piston leading to a pressure problem and the dead pedal. In your experience, could this cause the piston knock back issue you pointed to?
Happens all the time.
