Ok. I've never set up a 14 bolt so that makes me understand better.
In that case, did you reinstall any existing shims, baffles, or slingers?
Depends on the differential. Deeper just means moving the pinion closer to the ring gear.When we say deeper are we adding or removing shim?
You aren't making sense or I'm not understanding you clearly...
If you add shims to the pinion it should go deeper. Take away and it's shallower. What you are describing is backwards. What am I missing?
Yep 9 inch Ford, 14 bolt GM, most Eaton and Rockwell (Meritor) diffs use removable pinion carriers and the shim will move pinion away from the pinion.It’s a 14 bolt. Shims are between the case and the pinion Carrier. More shims moves the pinion carrier away from the ring gear.
Here is a 9 inch cutaway. 14 bolt works in the same way,And for everyone's viewing pleasure, can you post a pic of the pinion and how it is set up?
Thanks. I’m still not crazy happy with it.So looking at all the pics again, your pattern in #9 looks best to me. That would drive me nuts not having any shims less than 10 thou.
Here is the pinion carrier with the pinion gear installed. The gear rides on an inner and outer bearing, both of which are pressed onto the pinion gear shaft.And for everyone's viewing pleasure, can you post a pic of the pinion and how it is set up?
you can go to any GM dealers and order individual shims. GM doesn't offer shim kits for their bigger axles, you need to order individually.Try a G.M. Dealer for other size shims. I really would like to see a .005-.006 shim and .010-.012 backlash.
Thanks - That's where I'm headed....Try a G.M. Dealer for other size shims. I really would like to see a .005-.006 shim and .010-.012 backlash.
Thanks William.you can go to any GM dealers and order individual shims. GM doesn't offer shim kits for their bigger axles, you need to order individually.
I believe your setup concern is due to having the ring gear shaved. While its really not an issue, it's requiring a thinner than normal shim to get the pinion in deeper.
- 0.15 mm (0.006 in)
- 0.18 mm (0.007 in)
- 0.20 mm (0.008 in)
- 0.23 mm (0.009 in)
GM spec for backlash with new gears is:
Out of curiousity why was the ring gear shaved? I never heard of doing that.
- The backlash between the ring gear and the drive pinion should be between 0.08–0.25 mm (0.003–0.010 in) with a preferred backlash of 0.13–0.18 mm (0.005–0.007 in).
now I get it. I had assumed you were talking about the mounting surface of the ring gear. My bad.Thanks William.
The ring gear was shaved because I shaved the 14 bolt housing with a kit from Ballistic fab. You can see the detail over in my build thread, but here is the cut:
And the result:
That should get you going right there. Definitely no deeper you are on the verge of having a hard contact line near the root.Well, not wanting to leave well enough alone (I've got a problem that way...), I pulled the pinion gear apart and found a shim that would fit. It was thicker than I wanted at 49 thou, but it will work. It would certainly have been much easier just to get the thinner shims from GM next week, but I'm on a roll.
On the first shot I used a 56 thou shim stack on the pinion carrier to offset for the 49 thou added to the pinion gear - effectively making the pinion 3 thou deeper than my last setup. I did a pattern and it was going the right direction, so I pulled another 3 thou with a shim pack of 53. Backlash is 9.
And here is that pattern. I'm feeling better about it. It's nearly centered from the root to the face, and I don't think it's too deep.
View attachment 220348View attachment 220349
What do you think?
In the documentation from Yukon, they show an acceptable pattern for the 14 bolt can run off both sides of the tooth. it says not to worry about that, but rather the key element is centering the pattern from the root to the face.I would run that! Again, I would like a bit more backlash, but it’s not a deal breaker for me. Imagining the rest of the gear was there, the pattern looks nice. The only thing I worry about, is it looks like the pattern runs off the tooth, which will likely make a bit of noise. I will admit I have never set up a gearset that has been shaved.
Yes for any gear set you are wanting to be centered from root to crown and less worried about heel to toe. For comp use some will run on the deeper side but the gears will be noisy and run warmer.In the documentation from Yukon, they show an acceptable pattern for the 14 bolt can run off both sides of the tooth. it says not to worry about that, but rather the key element is centering the pattern from the root to the face.
Does that sound correct?
Hard to tell on these photos because the sight drops the resolution, but in person there seems to be a good bit of clearance to the root - about a 16th between the bottom of the pattern and where the root starts to curve away from the gear. And about a 16th from the face.That should get you going right there. Definitely no deeper you are on the verge of having a hard contact line near the root.
