Park under a tree and I'll bring my climbing harness for you. That way if you get to hammered we can hook a snatch block to a branch above the jeep and winch you up.
Where there's a will there's a way! Lol!
well now that we have my problem figured out, what are we going to do about that snake problem the rest of you have?Park under a tree and I'll bring my climbing harness for you. That way if you get to hammered we can hook a snatch block to a branch above the jeep and winch you up.
I'm debating buying a hammock.well now that we have my problem figured out, what are we going to do about that snake problem the rest of you have?
I'm hoping not to be stuck that often where I have to hand out enough jerky to constipate a horseDon't forget you'll also be full from all the jerky @Thunderhead will be passing out.
I have a real funny after Halloween/Party/trying to get into a hammock drunk/dressed as a caveman/with only a loincloth on story that might come in handy at breakfast in the morning.I'm debating buying a hammock.
I have 4 hammocks if you want to use one.
.........What shocks did you go with? If they are currie or similar be prepared to need a spring compressor.
I meant springs... But the ranchos are a nice choice.Sorry missed this on initial read. Went with Rancho 5000x.
Looks like they put currie springs the kit? Be ready with the spring compressor then. @bobthetj03 saw how much fun I had removing my 4 inch springs not too long ago.Oh 4” Savvy Lift.
That's going to be one awesome rig once your done with it. You and @tomtaylz will have clones.
How much lift did you net with the Currie 4” springs?Looks like they put currie springs the kit? Be ready with the spring compressor then. @bobthetj03 saw how much fun I had removing my 4 inch springs not too long ago.
64 wrenching days till the Con Run, what mods and repairs do all of you have to do?
I have to:
replace my front upper and lower CA’s
Replace u-joints front DS
Replace u-joints rear DS
Roughly 3.5" front 4" rear. Based off spring length. I never took measurements from the start.How much lift did you net with the Currie 4” springs?
Any reports on if the outhouses are still along the trail?
I can checkAny reports on if the outhouses are still along the trail?
