California Rubicon Trail Run
I have done them myself in the past. But this time I am planning to have them done because of the time crunch.
The savvy tuck and brakes could be done in a weekend. You'll likely need to take the jeep to an exhaust shop though and get then to add 1 inch behind the muffler and remove 1 from infront to move it a bit. The brakes were easy. What shocks did you go with? If they are currie or similar be prepared to need a spring compressor.
Yeah I can probably get most of it done in one weekend. Going to try to wait until it’s all here and just attack it at once so I don’t have to take the same stuff off over and over. :-)
Reactions: Alex01
I just want to see a video of you getting in it. I think I would have a hard time and I suspect I’m a few years younger than you 🤣
LOL I think my Jeep is closer to your age than I am (61 in 7 more days), I've been in it a few times to work the bugs out, but I step in the beadlock ring, then on the tire, roll bar above tub, and because I'm 6' tall I'm practically in it. I ordered a telescoping ladder just in case @bobthetj03 and @Indy twist my arm to drink scotch (thanks for the heads up @lowranger).
https://www.amazon.com/dp/B01MDO7IGT/?tag=wranglerorg-20
