Specs: LJR with NSG370
Whenever I'm wheeling in first gear (or any gear for that matter) low range and no feet on the pedals, I get this noise whenever torque is applied and removed. It's almost like there is play or movement in the chain or between gears? I can tell its coming from the transfer case and it does not make any noise in 2WD. Is this normal?
Thank you
Thank you
