I started the day continuing with the brackets I've been making. I welded the brackets that needed welding, and then bead blasted, primed, and painted them. I struggled with plumbing the manifold for the York OBA system (lots of leaks!) I lost my digital protractor somewhere in my shop (ugh, I hate when that happens) and had my wife pick one up at Home Depot while she was in town because I needed it, and two hours of scouring didn't turn it up. So most of the day was spent struggling, and it was frustrating!
About mid-afternoon, I decided to start my mods on Fluxor's hinge/spare tire carrier kit. My Savvy taillights interfered with the hinge pivot screws, so I had ordered some Keenserts to install in the bottom of the hinge to eliminate the nut on the pivot screws. I started by drilling out the bottom holes:
That was done in 1/32" steps up to 33/64", the tap size for the thicker 3/8"-16 Keensert. After getting the holes to 33/64", I tapped them for 9/16"-12:
To install the Keenserts, I clamped a piece of aluminum to the inside of the hinge to act as a positive stop for the Keensert and applied some red Permatex thread-locker:
Next, I screwed it in by hand:
Finally, I used the special tool to drive the stakes with a hammer:
The finished product:View attachment 649839
Then, I mounted the hinge bases, and installed the Savvy taillight. Continuing the theme of "I should have just stayed in bed today," I discovered that it wasn't just the nut on the pivot screw that interfered with the Savvy taillight. The housing itself has an interference problem:
In that picture, only one of the housing screws is holding the taillight. The other two won't fit. I'll have to remove some material on the hinge base in order to fix this issue. Stay tuned!
As someone with fluxor hinges sitting in a box and Blaine’s lights currently mounted, I’m following.
