Hello everyone,
I recently installed a Savvy T Case Cable Shifter. I installed a 1" Body lift and engine lift a while back and the oem linkage wasn't cutting it - I suddenly would pop out of 4H. I love the new shifter. However, I noticed some unusual behavior and I'm thinking it may be related to the T case. For reference I have a 32RH and 4L
When I am in 2H, around 30mph, 2000rpm, if I let off the throttle there is an audible and tactile click. I tried recreating the symptom in 4H.. it is still there but almost unnoticeable. If I wasn't looking for it I wouldn't notice. It feels like its coming from the tcase/transmission area and I assume it's related to the recent install. At higher speeds, the issue does not occur.
I imagine it is an issue of tuning the cable shifter. I am able to shift the transfer case into all 4 positions. I am wondering someone here with much better knowledge of whats going on inside the tcase might be able to identify or confirm the issue is related to the shifter. I know there isn't a lot of information to go on.
The only reason I am not 100% confident it is related to the new shifter cable is because I also replaced the seal underneath the throttle valve/gear selector lever on the 32rh. It was leaking massively. I imagine it's *possible* that could have something to do with it. Before I go and mess with the adjusting of the cable shifter I thought I'd ask if anyone here has ideas. Thank you in advance.
