Sentry Key Immobilizer Module (SKIM) Install / Retrofit
Ok thank you! At this point I just want to be able to drive my vehicle, only 23 Years old shouldn’t have to throw it away because of a part. Where is Mark located?
I went the easy way. I installed a Vandal Alert passive immobilizer. No wiring and consists of only two parts. I replaced my starter relay with the Vandal Alert radio controlled starter relay and that was it. It comes with a remote control. If you don't use the remote the Jeep won't start even with the key. A would be thief will never know where to look or how to bypass the system.
http://www.shop.cyclopsantitheft.com/main.sc
Thanks! That sounds smooth.
