C.J. Roberts
Apologies if I sounded gruff at you. My gruff tone was to the bad info.
First off, specific to our PCM, there is no knock sensor and timing is basically set on tables with only sensors like coolant temp, MAP, TPS, RPM, and IAT (I'm probably missing one) telling it where to look on the map. The PCM doesn't look at the O2 sensor for timing, period. What the O2 sensor does get factored in to is fueling in both long and short term trims, and all of this is in closed loop (read not wide open throttle).
The kernel of truth that gets twisted in to bad info is that the fixed maps the PCM looks to for wide open throttle can get moved slightly for lack of a better description by the long term fuel trims. The affect this has on WOT fuelling is small and the power difference is negligible. Now, the PCM can tell in closed loop that something changed and will try and get back to the program fuel ratio to a point (outside of set parameters and you get a CEL) but that only affects closed loop (part throttle) driving conditions.
The PCM has no way to see that you are running richer/leaner at WOT and it's not trying to adjust your new power away to get back to where it was. It doesn't have the ability.
No apology necessary. I'm not enough of an engine guy to know as much as you seem to, but what it sounds like you're saying is that changing components, (TB size, header, etc), doesn't do much at WOT, which most of us don't see very often anyway, but at LESS than WOT, (closed loop), when the PCM sees something different, the above mentioned TB size, etc, that it tries to adjust the change out of the system to get back to where it's supposed to be. I've heard that since the 80s, when they first started putting PCMs in vehicles. That's where the whole aftermarket"Chip" business started, to reprogram the PCM to take advantage of changes that worked on older engines.
If I'm reading that right, it sounds like we're pretty much saying the same thing. If I'm NOT reading you right, I'd like to learn what you DO mean.
As for the original comment by the OP, I was just trying to help him to not spend money that won't do what he wants.
Please type slow, as I'm not a fast reader.
