Shifting into 4 low on 2001 TJ
5632
Phoenix, Arizona
I purchased a new to me TJ and can not get it shift into 4 low. Had a very good Jeep shop look at it and they told me that the shift arm was to short and needed a longer one. This is an LS conversion with a 4l60. All the work done by the builder is very nice with a Novak system. I would welcome any suggestions or recommended shops in Phoenix.
I would pop off the shift linkage and see if you can get the T-case to shift into 4 low manually (with the vehicle off). If it goes into 4 low, then you have a linkage problem and it sounds like the Jeep shop would be right. You might need to rock the vehicle back and forth a bit to get 4 low to shift in manually with the vehicle not running.
Reactions: Goatman
Is the stock transfercase shifter linkage installed OR is the Novak system you are referring to the tcase shifter conversion ?
As Jeepguy stated.. IF you can manually shift into 4LO with the linkage disconnected; the problem may be as simple as a linkage adjustment.
The stock linkage throw Rod is adjustable....and a Savvy shift cable will solve the problem completely if it's compatible with what how you are set up.
Reactions: The shuggs and 5632
Agree with above. Detach the linkage at the transfer and see if it can be shifted manually. If so then I'd go with a cable shifter and never worry again.
