Short brake lines from m/c to combo valve?
hear
Can't type
Lifetime Supporting Member
Prosper, TX
Does anyone have a source for the short brake lines that go between the master cylinder and the combo valve? Turns out mine are frozen in place and my google fu is insufficient to find them. I'm sure I could probably have some made, but it might be easier to just buy the pre-bent kit if it exists.
I guess on a related note, do we know what size fittings are at the combo block & master cylinder? I've found a similar thing for some GM applications but I'm not able to verify if the threads match.
Don't auto part stores carry pre-made (unbent) lines in different lengths anymore?
Inline tube has them listed for a yj for 29$.might be worth a call to see if they have them for a tj. I bought their complete stainless non abs set to do an abs delete when the rubi axles went in
I searched there, but I only found them in the whole brake line kit. Do you have a link?
Thats why i said it might be worth a call. Only a full kit for tj's but they do have the 2 master lines for a yj.so maybe they would part with a couple from a tj kit?
Edit since some zj and cherokees use the same prop valve you might get lucky and find some at a junkyard?
Reactions: hear
if new for a YJ is only $30, going to a junkyard is not going to be worth the hassle. We have tons in DFW, but like 95% of them are like 45 min from the house.
