What skid plates would you recommend that are mostly flat and give the most ground clearance without the need for a tummy tuck?
Sent from my SM-G935T using Tapatalk
I researched it. Even with their lo pro mount, almost everyone that used it still had vib issues and needed a sye/dc shaft. One guy used the plate with lowering spacers as a temp fix. He lost some of what he gained but still had a flatter/smoother skid. There just seems to be no easy (read cheap) way to lift the t/c with a lower pro skid. Maybe diy if you weld/fabricate.I think UCF is one of the options that doesn't require a body lift as I recall.
I know @Luke has one.
2006
So I do not start another thread. Which Sye kit do you guys run and recommend? I have a 3" suspension lift.
