Smoothest bedliner?
Hammer24
Melbourne, Australia
I've decided I'm going to bedline or paint parts of my Jeep (fender flares, roof, front and rear bars, tub interior etc) because a lot of it is starting to look quite tired. I really like the idea of the added durability/longevity of the bedliner but the only reason I'm still considering paint is because I'd rather a smoother finish. Does anyone have a recommendation for bedliner that will give the smoothest possible satin finish? I've looked at the Line-X Ultra but the closest shop is 7 hours away and I'm hoping to do the job myself. Cheers
Durabak..
it comes in smooth or textured finishes. I have not sprayed it yet but plan on spraying the texture. They will send you a free sample. They sent me two different colors and it's pretty impressive paint samples. They have multiple videos on their website of doing Jeeps.
https://www.durabakcompany.com/
Reactions: TJ Starting
x
Durabak..
Thanks for the suggestion Leinhit, that's definitely an option. I've just asked for some samples so I'm keen to see how it looks.
Line-X is the smoothest. Just ask for no texture.
Line-X was what I was looking at originally but from my understanding they don't sell a diy kit you have to pay for them to do it? And in that case, I don't plan on driving 14 hours and spending a few nights there waiting for them to finish it lol
x
Ur Welcome
Let's us know how it looks, I was curious about the smooth as well.
Ur Welcome
Yeah I'll post my thoughts when my sample arrives. My only concern is that it might be a bit glossy. The textured definitely looked too rough but we'll see. Do you know how much the texture can vary depending on how it's applied?
I know with U Pol stuff the closer you spray the more rough the texture, spray further away for a finer texture. I saw you tube vids on it.
Reactions: Hammer24
U pol as in raptor liner? That's actually a really handy tip I hadn't heard that before, cheers mate
This vid talks about it some, it says to adjust air pressure to achieve different textures.. guy talked a bit funny but I suspect you will understand just perfectly.. :)
And as I said holding the spray different distances will also effect how rough the texture is. I like less texture myself but not completely smooth.
There’s a reason why they don’t sell a DIY kit. It’s a bad ass stuff and you need specialized equipment and knowledge to spray it. Worth every penny. But, I completely understand not wanting to drive.
I've used allot of the Rust-Oleum and it sprayed on with a fine texture.. seems to hold up well but I'm not using it in a truck bed.
I have had Linex spray some parts of my boat.... turned out awesome and even years later it looks great.
I also have some experience with Herculiner. It is really rough and gritty and quickly went to a flat, dull, black..... which I didn't care for much.
The Jeep has front and rear bumpers that have powdercoat on them that has chipped and cracked. Consequently they have rusted a bit. I plan to sandblast them clean soon. And I really like the idea of being able to do touch-ups quick and easily. The bedliner I've been thinking I will use is by Duplicolor & available locally in both a spray or roll-on. It appears to not be a super gritty texture either.
Check it out. And hope to see what you end up doing.
Good luck
Good luck
I think Duplicolor might be the smoothest. It's in that video above. They show close ups of the texture. If I ever use spray can bedliner I think that would be the one. It performed very well in his hardcore tests too. He runs a weighted rake over the bedliner tests in his truck bed. It's pretty brutal and only a couple of them stand up to it. And Duplicolor is one IIRC. You'll have to watch the video.
Reactions: Airjunky
Funny accent? No idea what you're talking about ;) So anway it looks like there's lots of factors affecting the texture which should keep me on my toes if I do tackle this myself.
And to everyone else, spray can bedliner definitely isn't out of the question, I will look into duplicolor so thanks again guys. Just waiting on some quotes now to see if it's worth doing it myself because that will most likely determine what I go with.
The benefit to doing it yourself (and especially with a spray can) is you can touch it up as time goes on.
Reactions: Airjunky
