I have the same... They work... But just barely. I've been looking for a better set. Will probably pull the trigger on the KnipexThese have been solid for me:
https://www.amazon.com/dp/B001B82G16/?tag=wranglerorg-20
Leaving Blaine out, because he knows, who all knows the washer and snap ring orientation?
For some reason these didnt work well with my JJ snap rings. They kept slipping out.
So i bought these and they have been solid for every snap ring ive encountered.
https://go.harborfreight.com/coupons/2021/04/174762-63841/
Interesting. I probably haven’t used them often enough to run into issues.I have the same... They work... But just barely. I've been looking for a better set. Will probably pull the trigger on the Knipex
The 2" joints are easy. The 2.5" joints that used on the lowers can be tough. Puts a lot of flex in the tool.Interesting. I probably haven’t used them often enough to run into issues.
I know, you are just the only one I know knows.I am not the only one who knows they only go in one way.
The Knipex do not flex at all on the 2.5 snap rings. Forgot to add that is the 90 degree versions where you really can't have them flex.The 2" joints are easy. The 2.5" joints that used on the lowers can be tough. Puts a lot of flex in the tool.
I bought the tool and don't use much of anything without reading the instructions, so yes.
You can easily make a tool with all thread or a bolt. You just need to be sure to clear the sleeve from the ball and brace against the JJ housing, then the other side pushes on the washer (leaving clearance for the snap ring to remove).Been trying to educate myself.
Anyone ever make a tool with all thread? I was watching Mr. Currie use one and wondered if it was ever done.
Thank you.You can easily make a tool with all thread or a bolt. You just need to be sure to clear the sleeve from the ball and brace against the JJ housing, then the other side pushes on the washer (leaving clearance for the snap ring to remove).
We were using all thread, sockets and washers long before Mr. Currie came out with the tool. You have to remember we've been running Johnny Joints since 2000.Been trying to educate myself.
Awesome. I wish I had a a decent rule of thumb for knowing what size goes where and how to read the specs better- I don’t want to derail but since this thread has JJ users maybe its relevant and the thread topic was sorta covered well....We were using all thread, sockets and washers long before Mr. Currie came out with the tool. You have to remember we've been running Johnny Joints since 2000.
Which way is the correct way?I am not the only one who knows they only go in one way.
Post in thread 'Measure Once, Cut Twice: A Story of Excitement and Impatience' https://wranglertjforum.com/threads...f-excitement-and-impatience.32913/post-658099Awesome. I wish I had a a decent rule of thumb for knowing what size goes where and how to read the specs better- I don’t want to derail but since this thread has JJ users maybe its relevant and the thread topic was sorta covered well....
Maybe it is like building interior doors from scratch like I did all day yesterday- I don’t do it often enough that I have to get reoriented every time.
Also Max at RockJock got into explaining how torque rotation of the axle makes the front diff joint (I think) want to pull apart internally and why he likes the narrower joint better for that application. I think I’m making it harder than it has to be. And I didn’t know one was a one piece joint.
Forgive me guys if I’m out of line. Just fishing for knowledge.
Sharp flat edges on washer and snap ring face out away from the race.I'm curious about the snap ring. I thought I knew the answer but my new Currie arms are installed like what I thought was correct, flat on the load side or flat side pushing out. As far as the snap ring which side is the flat part supposed to face? Do the newer joints have rings that are flat on both sides? I've only taken an older one apart and probably screwed it up. Is that even what we're taking about? I know it's not a huge deal but for u joints it would be great to know if I've been screwing that up too.
I was referring specifically to the Channellock 6" reversible snap ring pliers that were posted in the second post here. I would assume the Knipex don't flex at all. The Channellocks do...The Knipex do not flex at all on the 2.5 snap rings. Forgot to add that is the 90 degree versions where you really can't have them flex.
I've used the Channellock version once to take apart a JJ. It was borderline useless. Slightly better than two pieces of spaghetti.I was referring specifically to the Channellock 6" reversible snap ring pliers that were posted in the second post here. I would assume the Knipex don't flex at all. The Channellocks do...
