Snowblower Questions
I got the wheeled Ariens snowblower but not from the the line sold in the box stores. Buy it from an authorized dealer, they sell the "real" ones with better engines and housings. I found a dealer online that played ball on pricing and delivered free. The local dealers around me were all msrp. Anything made by MTD is coming from the same Chinese factory and is crap.
Well since my snowblower funds went into repairing my daughters car instead I worked on my old snowblower today. I'd bought a new carburetor for it but the linkage for the governor wouldn't work on the new carb because of the plate on top of the throttle. So today I used parts from the new carb and more or less rebuilt my old carb.
My fuel bowl was leaking so that got swapped over along with the gasket and bowl float and needle jet.
I also got a new muffler for it since the old one was in pretty sad shape.
Also installed a new fuel line since the old one was very hard and brittle. Had to remove the front engine cover to route the new fuel line.
All back together and ready for me to give a test run once I get some new hose clamps of the fuel line.
I won't install the cover over the carb until I get it running and make sure everything is working as it should.
Reactions: alittleoff
No air filter on our snow thrower either.
Years ago I had one of those moments, like huh, no filter. Oh yeah, if there’s dust and dirt,
I’m doing sumting wong.
Reactions: Wildman
And to address the original question...without a doubt I prefer a wheeled snowblower over the tracked. Honestly, I hate all snowblowers but the tracked units I've used don't do any better than wheeled (with traction) and are a bitch to move around when not running. I have great memories as a kid stalling out our POS tracked snowblower and my dad making me drag it back to the garage so he could "look" at it.
Reactions: Wildman
Well I got the hose clamps and installed them. It looks like my shutoff valve might be leaking just a little. It's not dripping but it is wet. So I'll order a new one and while I'm replacing it I'll put a new line in also.
But it's running and hasn't ran this good since I've owned it.
Well my leak at the shutoff valve was worse than I'd thought. I'd come inside for a few and when I went back out to the garage there was a big fuel smell and the side below the fuel tank was wet. Stood there and was able to watch it drip. So I drained the tank and will get a new valve coming.
With snow forecast for next week, I prepared my snowblower for the season. A few squirts of grease and some fresh ethanol free gas, it started right up.
Reactions: Wildman
Never would have thought finding a fuel shutoff valve with 5/15" or 8mm fittings in a 90 Degree would be so hard.
Try to tighten up the nut behind the round knob a little bit to squeeze the packing tighter, due to the age the packing is probably junk and it won’t help. Add a little extra gas line and use a straight shut off.
If it leaks a little at least you won’t have worry about the gas going bad!
Thanks for the suggestion. Right now it isn't leaking so we'll see how it does for a few days. I put a little fuel back into the tank.
Carburetor guard put back in place and secured. I forgot to remove the spring for the cold start assist 🙃 so I'll have to find a new one because it isn't on the floor anywhere.
EDIT: I found the spring so it's all done and ready now.
FTW !! It took me 25yrs to finally get the snowblower i deserved. Did the walk behind thing for years. A crappy big box Troy Built changed my mind forever, i now hold patents on new swear words.
Wife let me buy this bad boy and i was in heaven !! It was a BEAST !
Chewed thru over 3’ of snow on this pass, no walk behind could do that
Wow yes if I had that to plow I'd be going after a riding blower that is for sure. It is amazing what some of these things will do. If I had a bigger drive I'd be seriously looking at a tractor mounted snowblower. Plus we don't normally get that much snow. I'd guess 30-50" total?
That's what I'm talking about!
Reactions: Thatguy
You all want to know a terrible idea? Lining the easement of your property with pebbles instead of mulch in a snowy climate. We got our first snow yesterday, broke out the blower to clear the driveway / sidewalk, sucked up a golf ball sized rock & put a damn hole in my vinyl fence.
I have customers with gravel driveways, and when they bring me their snowblowers for service the things are always beat to hell and loose. What I recommend is lower the skids on the side a good 3/4" so it will lift the scraper off the ground a bit. This helps the machine not pick up so much gravel while still clearing somewhat close to the ground.
Reactions: Wildman and Mike_H
X2. Gotta get that scraper blade up off the rocks. I had to raise the scraper on my tractor mounted...it would grab a particular lifted block of concrete in my driveway and bring the tractor to a dead (and violent) stop!
Reactions: jeepguy03
Same here- -i struggled for years in Mid Wisconsin with a wheeled walk behind after my back was broken- steering the walk behind absolutely killed my back doing about 450' of driveway. It was absolute murder when i got to the road where the plow left frozen ridges. I was also a literal jerk if someone drove on my drive before i could blow it off because of the problems that caused. I ended up getting a JD x738 4WD with a 54' two stage blower and though I do not have a cab i do my two drives at home in 1/3 the time. It is so easy I do my 2-3 elderly neighbors drives also. It does not matter how much hard plow ridge the road crew left - my rig eats it up though when bad I may have to step on 4WD peddle and back off and hit it again. My drive would be impossible to use a truck mount plow due to the main drive being a U shape with the U bottom being at a 2 car garage--that makes the throw of 60' necessary to avoid doubling the depth.
My only question to Thatguy is about visibility when conditions can cause snow to stick to the glass? How does the cab work for you?
Reactions: Thatguy
