Sunday i messed with the cage some. if you notice the chunk of tube in the tub ( ^above), that's about the 3rd time the bastards fallen down so it needed some tacks b4 i needed some stitches.
anyways, pretty smooth sailing through the front portion and the mid section was ok, no issues. the back end has a bit of an issue.
the instructions provided say "to have a buddy hold up the back bar and tack it in, continue to hold it while the rear supports are placed and tacked. there are etched marks on the bars for alignment".
well there are etched marks on the rear support bars (blue). there is no marking on the back bar (red). there are etchings for the bottom of the support and the end of the back bar on the angled tube (yellow) that show me where it should all hit.
here it gets all tricky, the back bar (red) leans down, that's how it's cut to fit best. the support bars (blue) reach the back bar from the etches like this.
now the header bars (green) will not reach the back bar (red) unless it's up level and the cut on the end of the back bar (red) is not coped right for that position nor does it hit the etching. and it's above the supports (blue) reach now.
with the back bar (red) placed in the etches and leaned and hitting the support bars (blue) placed in the etches, the header bars (green) are a 1/4" short of reaching that back bar (red).
now i'm dizzy..........the short of it is i'm gonna alter the headers (green) rather than 4 other pieces that seem to be where they belong, and leave a little lean on the back bar (red).
so i took the headers in today and cut them in the middle and made up some 5" inserts from 1.5" DOM. now i can stretch them to reach. both the support bars (blue) seem to favor just off center in the bend with their natural fit , so i'll use that spot i reckon.
