My steering box is rusty and leaking. Wondering if I should clean up and rebuild, by a remanufactured or something like this amazon add since I will be going to 35’s. Is this amazon unit just hype?
Thanks
Thanks
Or not.You might check out the Durango steering box upgrade:
https://wranglertjforum.com/threads/dodge-durango-steering-gear-retrofit-faq.4113/#js-post-54450
Not worth it?Or not.
Not really. It is from an IFS vehicle and has a bushing instead of a bearing at the upper end of the sector shaft. All the aftermarket offroad steering builders machine that out to accept a bearing that is standard in gears on all SFA rigs.Not worth it?
Sorry, saw the Durango thread after I posted the question. Waiting on Blaine’s answer as to why the Durango swap may not be worth it.You might check out the Durango steering box upgrade:
That makes sense.Not really. It is from an IFS vehicle and has a bushing instead of a bearing at the upper end of the sector shaft. All the aftermarket offroad steering builders machine that out to accept a bearing that is standard in gears on all SFA rigs.
I don't recommend any. I use PSC and a lot of it but it is expensive. When you have a problem, you'll know it and solutions will present themselves.That makes sense.
What do you usually recommend then? PSC steering gear?
What do you use for the 03-06 when the gear goes bad? Remanufactured OE steering boxes? Looking at those they’re not cheapI don't recommend any. I use PSC and a lot of it but it is expensive. When you have a problem, you'll know it and solutions will present themselves.
Stock low mile take outs when we can find them. Typically by that point the owner is ready for something bigger and better.What do you use for the 03-06 when the gear goes bad? Remanufactured OE steering boxes? Looking at those they’re not cheap
Basically, stock unit is fine with 35’s?
Thanks Chris, definitely nothing that hard for me. I know I have a leak and clean up so wasn’t sure which way to go.Yes, the stock unit is just fine with 35s.
What he's saying is that there's no need to "upgrade" the steering box unless you can actually find a reason to upgrade it (i.e. you need hydro assist). If you really want to upgrade it just for shits and giggles (for instance, you're a "mod collector" like I am), then add a PSC unit.
But you certainly won't need it with 35s unless you're out in the rocks doing some really hard wheeling, at which point the problem will present itself.
I'd just replace it with a stock one, or have your existing one rebuilt. I'm not sure who rebuilds them, but I'm pretty sure they can be rebuilt fairly easily (could be wrong).
West Texas Offroad will rebuild it. Though I recall someone saying they didnt get their same box back...A buddy of mine has used them for a few boxes and he really likes working with them.
I should buy one of those from you, if you have any, as a spare as there's no way I can afford a PSC nowadays.Stock low mile take outs when we can find them. Typically by that point the owner is ready for something bigger and better.
