X2. The taller the suspension lift the more off to the side the front axle will be with the factory track bar. An aftermarket adjustable length track bar will be required to get the axle centered. Same with the rear. The below track bar is an aftermarket whose length is adjustable for centering the axle. The factory track bar length cannot be adjusted.
This is why the suspension height affects the axle's left-to-right position. Lift up the top horizontal line, which represents the chassis, with a suspension lift and the diagonal line representing the track bar will pull the lower line representing the front axle off to the driver's side. The rear axle's track bar is connected onto the opposite sides so it pulls the rear axle off toward the passenger side.
