It's been a while since I posted an update on the TJ Build. July was spent working on getting a turbo out and back into my truck while most of August, I shifted efforts to get the Buggy trail worthy.
I did get the Genright comp tank "mocked up" for install and didn't like the way its forward mounting tabs hit the center crossmember/tank support. Since this support will no longer serve as upper shock mounts or gas tank support, it's only function is to support two body mounts. I knew it needed to be modified anyways as normally, 4-link mounts will interfere @ full stuff. I cut the crossmember out in prep for a small piece of steel C-channel.
Currently, the only support for the frame rails, from the skid back, is now the rear frame crossmember/bumper support. I've debated a back-half kit but I want to retain stock frame width. Measuring where the frame arch is in relation to the center of the fender, It's exactly what I've been planning.. 5.5"
Who here has stretched a TJ frame? What's the correct way to shift the arch back to match the opening?
A. four large fishplates on each frame rail with a 5.5" piece of box tubing?
B. 2nd clean frame cut 5.5" longer then fishplate both together?
I haven't done it, but if I were to do so, I'd cut it near the last mid tub mount (the ones outside the frame) and weld in the extension there. I'd plug weld some plate on the inside of the tubing, to make a tab if you will, on each of the 4 sides and slide my extension over top. Then weld the seam and plug weld the extension. Finally, I'd fish plate the frame toward the center of the vehicle.
That moves the whole arch back and you trim 5.5 inches off the rear of the frame and re-attach the cross-member.
