Here is the front of the tank and the shock crossmember. I had to grind down the heads of the bolts to clear the tank but may still get some button head bolts instead. But I do think making your own crossmember would be a better idea.
As you can see it's stuffed up there about as tight as it's going to get. Of course, the other option is to cut the tub and raise the bed of the back so the tank can sit higher in frame.
I'm using 1" x 1.5" aluminum bar to make the spacers for the rear mount points.
