Striped Motor Mount Bolt
Kevin Q
Perkiomenville, PA
I'm in the middle of the body lift and motor mount lift. I removed the top drivers side bolt and went underneath to remove the bottom. I am using the correct sized ratchet and I am pretty sure that the bolt was striped before I started. What the heck do I do now?
Is the hole just stripped of threads or is the boss broken?
I’m not following you, the head of the bolt that you put the socket on is rounded off?
I went back out there and got it off. I think I was using too long of an extension which was causing it to angle a little.
Honestly, this one is making me a little nervous. I don't really like being under the Jeep while removing the mounts. All I have left to do on the drivers side is remove the bolts from the motor, swap in the new mount, and replace.
Reactions: Daryl
I've had good luck with these type of extractors along with my impact wrench.
Reactions: MountaineerTom
Be sure to have jack stands and have the engine supported and you'll have no worry about being underneath.
Reactions: Fonz54
