Here’s the flush follow up; potentially several bad fan clutches?
Flushed the system with distilled water and Prestone radiator flush and there was a small amount of sediment that came out of the system but not enough for me to believe there was casting sand or rust scaling inside the engine causing overheating.
HOWEVER, I do want to explore the possibility of my current fan clutch (as well as others) being defective which I captured in this video link:
Potentially Defective Fan Clutch?
I took a video under the hood at 226.4*F engine coolant temp and noted that the fan clutch was rather silent, almost making no noise with the only audible sound being the valve train running despite ECT being near maximum safe operating temperature and ambient temperature being 103*F. Because this is a
USMW 22159 Severe Duty Unit, I was under the assumption under this much heat that the clutch should be roaring, almost like a school bus or a Freightliner but it’s not audible at idle
OR under load while driving.
While the odds of it seem rather low, is it possible that I’ve just recieved a handful of bad fan clutches that were dead on arrival? Curious to know everyone’s thoughts on the video I made linked above.
I also picked up at Shaw 330-195 brass thermostat and will be installing it later this weekend or early next week, but the current thermostat in the system appeared to be operating normally.
