If I have a Dana 35 w/3.73 gears - doesn't the Super35 kit that comes w/bearings and seals need something changed in the carrier as well? I remember reading something along those lines but can't find it again.
If it's just axle shaft swaps w/new bearings for the outer ends of the axles I can handle that....if it involves re-setup of the gears then I can't. I think I remember the spline count being different which requires a new carrier(and also re-setup)
Just trying to confirm if I might be able to handle it given the parts. The cost is doable if I can do the labor.
