Super tech gear oil
Wild Bill's ‘98 TJ
Laurel, Ms
Does anyone know if Super Tech 80w 90 gear oil is ok for limited slip differential?
It is “GL5” but doesn’t say anywhere on the bottle or the internet (that I can find) that it is ok for limited slip.
Thanks!
It's fine, but you will need to get some limited slip additive and put it in with the gear oil.
It's back label confirms it already contains the limited slip friction modifier additive. It's hard to find a GL-5 without it.
The synthetic does, but not the conventional. Conventional only states recommended for LS and does not state that it is suitable for total replacement.
Yes, but they all say that as they are suitable for top off of LS diffs that already have additive in the oil. The ones with LS additive specifically state that they are suitable for total refill and contain LS additive.
I found this to be the case recently with conventional Valvoline 85-140 also. No additive, so I added a bottle of MOPAR additive to it.
We'll have to agree to disagree on the interpretation of that blue label. That it says it's only for unsynchronized transmissions means the friction modifier for clutch-based LSDs that would fuck up transmission synchronizers is present.
Reactions: g.hayduke
The syncro (yellow metals) eater is the sulphur in the GL5s. Jeep screwed that up in the FSM and owners manuals for the AX15 by recommending GL5. I really have no idea how the FM would affect the syncros.
All I could find online was the the FM they put in the syncromesh type lubes for MTs is different than the FM used for LSDs.
