Looks like my oem sway bar links are worn out. Any ideas what are a good brand for replacement? Also should I just replace them with quick disconnects? I was looking at Jks or rubicon express discos. Looking for some ideas. thanks.
Don't do disconnects until you unbolt them at the trail head a few times and get tired of doing that. Disconnects wear out faster than factory style and if you don't use them they are a waste of money. I'd run the plain factory style $5-10 links on Rockauto without a second thought. Like @P man says if you have much of a lift you probably need longer links, the sway bar should rest around level or slightly high towards the rear of the Jeep in the front.Any ideas what are a good brand for replacement? Also should I just replace them with quick disconnects?
O lift all stockIs your jeep lifted? How much off reading are you planning?
Airing down is cheaper.Swaybar disconnects are the cheapest method of adding a lot more traction/stability to your jeep.
Got mine from Rusty's Off road
Just got these. Like he said.I just installed Moog end links. Exact fit and easy to install. I liked the fact the top bolt had a hex fitting at the end to keep the ball joint from spinning as I tightened it down. Next up are my rear end links (and I went with Moog).
Keep in mind they have poly bushings, some prefer rubber.
Is Moog giving away Poison Spyder decals with every order?
Well my thinking is if ya don’t have a 4” lift with 33s and as many mods a person has bills to pay. I’m sure it’ll all be fine man.Is Moog giving away Poison Spyder decals with every order?![]()
Well my thinking is if ya don’t have a 4” lift with 33s and as many mods a person has bills to pay. I’m sure it’ll all be fine man.![]()
thanks .I just installed Moog end links. Exact fit and easy to install. I liked the fact the top bolt had a hex fitting at the end to keep the ball joint from spinning as I tightened it down. Next up are my rear end links (and I went with Moog).
Pulling a holy thread revival. Anyone else order these MOOG parts and have them not fit? 2006 LJ. Taper is way to big.
Never had that issue..can you post a pic of the taper on the link and another of the taper on the sway bar please?
They fit my 06 fine. P/N K3197
