I'm thinking about makin' some changes to my heep. right now its got some 2.5" lift springs on it, AND it still has the 1" belly pan spacers on it from when I bought it with the stock shovel. Now, I'm thinking about getting rid of the belly pan spacers, a new skid plate and some new control arms rather than the stock stamped steel ones.
I'm reading that with a 2.5" lift a SYE and double cardan shaft isn't required. I can set the pinion angle to be parallel to the t-case with the adjustable arms, so not a concern there.
I do plan on adding highlines and 35's in the future and sticking with the 2.5" lift. I have my tent on top and its a pain to reach as is, hence why I'm not doing the normal 4+1.25 lift. 2" of increased height is enough, I don't want it 5" taller than it is now.
Is there any actual benefit to adding a SYE and double cardan with 2.5" of a lift, or is it really of no actual benefit without more lift? This rig isn't a hardcore crawler by any means, its my camp rig and I'm going for bigger meats for the footprint/lower ground pressure more than anything for snow. Only thing I could think of for the SYE being beneficial is it should be a bit stronger having less angle on the joints, but I'm not pushing it that hard yet anyway.
