picked up this new Amana microwave on Friday at Lowes, $199, the one it replaced had been there since my kitchen was installed in 02 & it was the only one I ever had so I wasn't really sure how they were mounted.
That was a pain in the balls.
Some quick measuring I noted that the holes seemed to be universal, though I needed the new wall bracket it came with as the hinges were in a different location, and as it turned out this oven was one inch taller so I had to move the bracket down an inch. Naturally that put it half on top of the existing tile, some shimming resolved that issue.
The real problem came when I neglected to measure the depth which was also one inch greater than the prior unit, so while the existing holes in the cabinet up top were the correct width, they were an inch deeper into the cabinet. I learned that as the oven was hooked onto the hinge and I was holding it up with my knee while searching for the bolt holes in the microwave from the cabinet up top
Not wanting to take the whole thing down, re-drill the holes in the proper locations, or use the template that came with it like a competent person would have, then re-hang the oven due to it being a mother fucker for me to wiggle in there to begin with, I chose instead to hold the thing up with one arm while collapsing my painter's ladder with the other and jamming it under the oven laterally to hold it up. Once it was stable enough I grabbed my giant butcher block cutting board which was far more stable than the tapering ladder legs, and swapped them. Once that was done I went back in from the top and drilled the new pilot holes. Did that by eye
Fortunately it all lined up & I got the bolts in & all is well.
This is pretty much how all my home improvement projects go, often there's some kind of minor injury, so without that I consider this job a smashing success. Delivery and installation would've exceeded the cost of the piece of shit oven so that wasn't an option. At least when I have to replace this one 3 years from now I'll know (better) how to do it...
