Roger Descoteaux
I'm curious because I'm about to do a RC 2.5 with 31s
After installing the same RC 2.5" lift (before I discovered this forum & found out that I should not have chosen RC) I can say that it works out just fine as long as you do everything else that surrounds the 'lift', meaning alignment, balancing, TC drop if needed, etc. I have an '06 and after the lift it operates just as it should.
