Third brake light woes
Gregg1LE
DFW, Texas
My TJ passed Texas State inspection last year with an aftermarket LED setup with 3rd brake light and license plate light.Please see photo.
I tried to get it inspected last weekend but was rejected by two different places for improper 3rd brakelight . I asked what was acceptable and one of the inspectors
said she would accept the 3rd brake led ring that is so popular and the other inspector said nothing but a high brakelight with a DOT approved lens would do.
I guess that Texas has clamped down on what us Jeepers can run as far as the 3rd brakelight is concerned.
Any suggestions on some economical yet practical solutions to this? My spare tire carrier is a Smittybilt XRC with a 20 inch wheel and a 35" tire. The wiring in back has been heavily modified with back facing LEDs and aftermarket tailights.
Thank for any and all advice in this.
Did you find a solution? Having the same issue in VA with my 04 Rubicon. Can't seem to find an aftermarket third brake light stamped with the DOT approval. The specs on this one say "DOT approved" on the seller's site. But other, older posts list this model as NOT DOT approved.
Could the OE 3rd brake light be attached to the wheel or carrier somehow? Perhaps saw off the housing and screw or even zip tie it to the wheel or carrier
Thanks Gents! I bought the brake light that Gregg1LE got- I'll cross my fingers- and then I'll add the LED tire ring later if I whiff. Also keeping the old OEM set up in case I have to retrofit the whole thing for inspection. They tried to jack me on my LED headlights a while back until they found the DOT stamp- but I'm thinking that is only for the front headlights and that I can get away with an OEM looking new brake light set up. I appreciate the replies!
