Thedogsbollocks
Ok whatever...you’re wrong but that’s o
no...but that’s ok. A head unit simply cannot reach the capability of a DSP but if that’s your view that’s ok.You can use a DSP and it will definitely sound better. Though it won't come anywhere close to an aftermarket HU which is going to produce a clean signal. Instead of a crappy signal that has to be cleaned up. Again, priorities. If you must have that factory look, by all means. You're spending a lot of money on clean sound, but the initial sound (HU) is a mess.
You don't even have to get an expensive HU. A $200 Alpine would eliminate most of the headaches of the OEM HU. Especially considering the OEM HU is around 20 years old for most, definitely behind the times.
