JPHikr
Opps cant fix stupid.
https://gothamist.com/news/snow-go-...tm_source=twitter&utm_campaign=shared_twitter
I put gas in my Jeep and it starts right up.
Unless it needs repair just like that guy's Tesla.
I believe it’s inevitable that EV will be a common site on the most challenging trails in the future. Just when, likely depends on the aftermarket, spare part availability and dependability. Considering how many rigs are trailered to the trailhead today range of the OHEV isn’t a deal breaker. And yes, the tow vehicle will likely be ICE powered.
A couple links here about SEMA / EV aftermarket I found interesting- esp the amount of floor space SEMA has seen increased at the show.
I included a shot of what may be new off road challenges that an OHEV can allow for us!! …. Hold my beer….
https://www.thedetroitbureau.com/2022/07/gm-set-to-join-fast-growing-ev-conversion-market/
https://motorsportsnewswire.com/2022/10/20/electric-vehicles-immersed-throughout-2022-sema-show/
https://fortune.com/2022/12/25/convert-vintage-classic-muscle-cars-into-electric-vehicles-ev/amp/
Wont do any good until battery technology improves.
Somebody in the aftermarket is going to start selling straight axles with electric motors in place of the differential. When they do, EV conversions for TJs and such will become much more doable and we will start seeing some trail worthy EVs. If I was at a company like Dana/Spicer or maybe even smaller companies like RGA or Advance Adapters I’d being pushing to develop that product line.
Traction motor setups are nothing new. While that sounds good in theory, a major problem with an electric-motor-on-axle idea is the physical size of the motor. A common 1.5 hp water pump motor is approximately 12"x8"x10". That's not enough power to move a vehicle. Here are some published dimensions for a 100 hp electric motor. It's about 2/3 the size of a small block Chevy. Definitely not going to fit under something like a Jeep TJ or other common off road vehicle.
Yeah, that’s big. And I’ll admit I am thinking big picture without complete knowledge of the details (important as they always are). However, I am aware of several vehicles running individual e motors at a wheel so I guessed the packaging could be figured out. Maybe?
Why? What leads you to believe this, or are you just echoing the headlines of the day?
From one of your links, another significant hurdle.
"Indeed, conversion costs run all over the map. Some can be accomplished for as little as $8,000 to $10,000, according to experts. According to GreenCarStocks, most potential customers should expect to spend at least $18,000 — and $30,000 isn’t out of the norm. Indeed, experts caution potential customers that six-figure projects are not unusual, some more sophisticated conversions running to $250,000 and above."
For a 4x4 thst is solved with a reduction gearbox on the motor routed to a divorced Atlas transfer case. Reduction boxes available to the aftermarket are still kind of rare and usually designed around a specific motor package but hopefully that will eventually change. And then we can wish for two speed boxes. But none of that will probably happen without a 4x to 6x improvement in battery energy density so that we don't have to fit and build around 1,000 lbs of batteries.What? Motors aren't the hold up, batteries are. The challenge with MOA is unsprung weight. Nobody wants solid axles due to ride quality, much less a solid axle with a motor.
Another challenge is you'd really want a transmission to get good crawling control and highway performance. Electric motors have a relatively large operating window vs gas, but it's still a window.
Imagine a solid axle with this drive unit cast in.like an electric golf cart axle.No heavy ring and pinion or carrier. Probably heavier than a conventional diff but arent these tesla motors capable of 500hp?
Lifting an ev with an axle like that would be easy.
I'm not an electric car cheerleader, but i'd drive one if it wasn't ugly,made financial sense and was fast.
I hardly ever use pneumatic or corded tools anymore. Its lithium battery cordless mostly.seems to be the way tech is going.
How big is that, and how big would it need to be in order to move something like a Jeep on 35"-37" at reasonable speed is the real issue.
