2003maroonTJ
I have all of my carpet out right now to lay down noiseproofing and have the same mark (mine is also bright silver metallic).
I’d like to know how the noise proofing worked out.
Welcome!
It worked out well. I covered almost the entire tub, but I think you could use less and still get good results. Also, I could still benefit from some reflectix on the tunnel to block some of the heat.
Here’s a thread with lots of info:
Thread 'How to sound deaden the interior of your TJ'
https://wranglertjforum.com/threads/how-to-sound-deaden-the-interior-of-your-tj.16153/
I found a used butt plug under my center console when I took it out fwiw?
Not so much an Easter egg, but something cool I found. I found “SB” engraved into my paint under my driver seat and behind the driver headlight. My old Jeep was “Bright Silver Metallic” and the paint code was “PSB.” Every Chrysler vehicle paint code starts with “P,” so it dawned on me that my paint code was physically drawn into the wet paint.
Can anyone else confirm their’s is the same?
Ok so recently I found out that jeeps have "easter eggs" which appear to be various hidden emblems or phrases,etc (just do a Google image search ) pretty much All images are from newer jeeps though.
After some research I've read that jeep started this trend with the TJ but I can't find anything on mine. I was wondering if there is in fact Easter eggs on the TJ and if so where to look for them.
