the OP never has said if he did/had a alignment done after installing the lift. like Jerry said it will affect toe-in and would make it handle exactly as described !
Mine handled like a boat- I quit pulling skiers after the cops got on me.
so now you just use it to gather up ducks ?
Lifting a Jeep turns out to be a much more involved process than adding spacers to the springs.
Complete lift kits from a quality manufacturer can help, as they are fairly comprehensive. But also expensive.
OP, I'd look at getting rid of the trash spacers, and do the lift correctly... unless your offroading will be limited to crawling at the local mall...
Lifting with spacers will cause you nothing but grief... you cannot take advantage of the full amount of travel that a lift spring will get you, they spacers can be noisy, they will degrade and break apart over time, will cause the same amount of work a real lift would have caused...
I have a 2in. spacer lift with no problems. many will hardly ever use the full travel anyway and just want a little lift for a little bigger tires. I didn't want to mess up my ride by changing out spring so went with the spacer lift. it's all up to the wheeling you plan on doing as to if the spacer or full suspension lift will work for you !
2” of spacer lift is pretty workable- your axles stay close to center - caster is tolerable, etc. -Somewhere in the neighborhood of 2 inches is pretty much the breakpoint for a budget boost- my 06 Black Bedlined Rubi was super with 2”, at the same time lockers really compensate.
Beyond that it’s time to think more expansively.
Wow. I used a big word. May I have 10 Bonus points Chris? I’ll use them wisely.
I was thinking 3in was a little much but figured it was the same weather a spacer or springs.
There comes a point at which the job should be done the best way the owner can afford. I did mine piecemeal, and the event that convinced me it was time to get off the dime was when I needed tires. Didn't want to put the original sized small 31s back on for another several years. Nor did I want to buy tires that fit, then have to buy larger tires again after I installed a moderate lift. So, I bought the 33s and wheels around the same time I ordered the initial lift kit. Drove very carefully for about two weeks with the big tires maybe every other day, only on pavement. When the lift kit arrived, I began install right away to keep from rubbing the tires frequently. Everybody has to do it their own way. But I agree. Spacers can only be a temporary option, at best. Unless, of course, the lifetime of the Jeep will be spent only on local streets.OP, I'd look at getting rid of the trash spacers, and do the lift correctly... unless your offroading will be limited to crawling at the local mall... Lifting with spacers will cause you nothing but grief... you cannot take advantage of the full amount of travel that a lift spring will get you, they spacers can be noisy, they will degrade and break apart over time, will cause the same amount of work a real lift would have caused...
Have you seen the new speed bumps at the mall that Biden put in with the infrastructure money? You need a TT to keep from scraping on them.OP, I'd look at getting rid of the trash spacers, and do the lift correctly... unless your offroading will be limited to crawling at the local mall...
you say they're a temporary option at best ? why does the metal their made of disappear ? and if so how is it different than the metal your springs are made of, or the factory springs for that matter ! also why aren't the body spacers only temporary ? mine have been on for 2 years now and I'm satisfied with the ride and lift I have but how much longer can I expect it to last before it disappears ? OH AND MY JEEP STAYS OFF-ROAD, nothing extreme and I don't jump it off cliffs (so I don't need 16in of travel) and it does what I expect on 31's MT's.
Spacers are fine. I don't know what everyone is in a tizzy about. You just have to get the accompanying mods to fix the geometry you messed up, but up to 2" is fairly normal and fine for a lift as long as you get some longer shocks that work well at that lift height. Make up your mind if you want to re-center the axles, which can be done cheaply and effectively.
Agree that a 3" puck lift is just way too much. I wouldn't go over 1.5" or so. If you need to go higher than that, buy the springs you need.
