First thought:
You should have 5V going to the sensor and .5-5V going back depending on throttle opening. If the voltage changes like it is supposed too, than you have a computer problem. If the voltage is pegged high than you have a ground problem.The third wire to the sensor is a ground. It should always read 0V. If it reads more than that, you have a ground problem for the sensor. (
It can also be caused by a bad computer ground. If the computers ground is bad it will cause it to read the TPS signal incorrectly.)
Second thought:
TPS faults can sometimes be clockspring related.
- Unplug your clockspring to the steering column.
- Remove the plastic cowl behind the steering wheel.
- If you look under on the left side you will see 2 small connectors that go into the clockspring. Just unplug them and try it.
- You will need to unhook your negative battery terminal then turn the lights on for about 2 minutes to ensure there is no charge left in the system anywhere.
If it works you have found your culprit and will need a new clockspring.
