A class 3 will get you a much higher tow rating than the jeep is rated for, however it will also give you a 500lbs max tonge weight. That will help you in the case of a basket (depending on how much you plan to load on it) as the further out from the hitch that weight is the more it multiples in the actual tonge weight. Also don't forget the forces of all that weight, on a leaver, going over bumps if you are on bad roads. The only thing that ever goes wrong with too much trailer hitch is your pocket book. Incidentally I'm also a fan of the hitch being built in to the bumper for departure angle reasons.
There must have been a time
when we could have said no.
