Thank you, just switched it over!View attachment 173023View attachment 173025
@jkowitz Set up your stabilizer like this.....***correction
You'll be perfectly safe at 12 in a TJ.I actually didn't air down, we weren't on the trail for more than a few hours. If I was going to air down I probably would've gone to 15psi
For now just enjoy it, but some things I want to save up for soon are bumpers and building a small storage/organization shelf in the backYou'll be perfectly safe at 12 in a TJ.
What's next on the build list?
The tummy tuck is definitely on the list, I'm just worried about lifting the Jeep to high. I have noticed it kills the ground clearance on the TJs so it's probably going to happenThe rig will tell you what’s needed for what you enjoy. I’ll bet a few tucks may be in your future along with the bumpers! The transfer case skid (shovel) hung me up a lot and I nailed the gas tank skid a decent bit but it wasn’t as big a hang up as you can slide off it.
Savvy is a great option for a full tuck. I would have gone that route but they no longer make one for my year/transmission. The nice part about that system is that it will allow you to drop your skid without needing to support the transfer case. Another one to look at is UCF.The tummy tuck is definitely on the list, I'm just worried about lifting the Jeep to high. I have noticed it kills the ground clearance on the TJs so it's probably going to happen
Thank you! It's a poison spider fairlead mount I found on amazon@jkowitz sweet build so far. How are your KCs mounted to the winch/winch plate? I like that look
Either way, better than disconnectsThe Swayloc might be a better option for a top heavy TJ with a rack and RTT on road and it’s every bit as good as the AR off-road.
I agree, disconnecting with a top heavy rig is also not the best thing to do eitherEither way, better than disconnects
Or @jkowitz take those windows off and enjoy hanging out over the half door.So who’s making the swap with him for the half doors? I have those same sliding glass uppers. Maybe a set of soft uppers with zipper windows would be better?
