It is common to swap parts to test them so one could easily make a reasonable case for doing so and not get penalized. The ones that will raise flags are the dash, matching VINs in the cluster and PCM, and the one on the frame. Law Enforcement at the traffic stop level only cares typically about the dash and door jamb matching and being present. Law Enforcement at the inspection level and US Entry are a different story.Mr. Blaine, thank you for your input again. That is the reasoning behind the swap. I did think about swapping out the complete dash and order a replacement Door jamb sticker. But the 2006 wrangler has the VIN on almost every part (assume to stop strip shops) and didn't want to risk any issue on it being shipped back. Better to put the hours in and swap the parts I need. Thank you again for all your help!
We helped a guy who was a US citizen who lived in Mexico for awhile and wanted to bring the TJ home that he bought down there. The conversion to US miles instead of kilometers was painful and it took him about a year to get it done jumping through a bunch of hoops.
