For the last 35 years I have worked as an electrical engineer for the Department of Defense and in those years I have taught 1000’s of military personnel how to troubleshoot aircraft and their systems efficiently, quickly and cost effectively. Whether you are troubleshooting a $100,000,000 aircraft or a $10 toaster the principles are the same. Hopefully these will help you when troubleshooting your Jeep and save you some money at the same time.
1) Never throw parts ($$$) at a problem
2) Understand the function of the system that is failing
3) Determine what has changed or was touched since it worked last and look there first
4) Sit back, think, and come up with a game plan
5) Understand the system failing
6) Is there something I can swap, e.g. 2 injectors, that will give me information?
7) Is there a way to verify a part without replacing it?
8) Go for easy stuff first
9) Understand the system failing
10) Be patient, be thorough and not afraid to ask others.
Good luck and get her fixed.
